I have the following defined in my WebDialogWindow:
<ClientEvents WindowStateChanged="wdwStateChanged" />
And a Javascript function as so:
function wdwStateChanged(sender, args) {
I would assume that when I set the WindowState in my code-behind to Normal, it would execute this function when my code behind is done and control goes back to the browser. However, the wdwStateChanged Javascript never seems to execute. I wanted to use this function to check to see if the WIndowState was Normal and if so, set some other items on the WebDialogWIndow (in my case, turn on/enable a timer).
How can I use this WindowStateChanged client event properly? Why isn't it firing?
/Tom
Extra parameters in some public functions/properties (like second parameter in set_xx or a parameter in get_xx) are not officially supported or they were designed for internal usage. Because in some scenarious, they may produce misbehavior or break control.Advanced applications may learn (in debugger) about those special features as well as about internal _xxx methods and variables, but that is beyound techsupport and application is responsible for possible side effects.
Is there any chance that you can update your documentation to reflect this? At least, 10.2 does not show this boolean parameter. I have noticed the missing parameters/ methods in documentation.
Hi Tom,
All client side events are designed to process entries of end user, but not to raise events on internal actions of application (otherwise, it would be easy to get dead or recursive loops and other misbehaviors).
If you use get_windowState(state) and also want to raise client state-change event, then that method (or set property by dot-net standard) can take extra boolean parameter.
webDialog.set_windowState($IG.DialogWindowState.Normal, true);
If that property was modified on server, then no events will be raised on client or server.
