I am relatively new to using the WebScheduleInfo class.
We are using 3 WebScheduleInfo classes, where the first one is the current month, the second one is the next month, and the third one is the month after that.
When setting up controls 2 and 3, how can I avoid setting the active day, but still get the control to display the date range I want?
For example, I want one active day to be available to be set, across three WebScheduleInfo objects. Right now, each separate WebScheduleInfo has its own ActiveDay set, and it does nothing when I select this day, because it is already set as the active day.
Chuck
Thanks for the reply. How do I go abouit doing that? If using one WebSchedule control, does it show up together or as separate months? I am new to using Infragistics ASP.NET controls.
I'm not sure this is the best way to design the solution. Have you considered one control showing 3 month range?
