Hi Derek Harmon,
I resolved this issue. I have used extra "}" in my coding that was causing the problem.
Now its through. Thank you.
I have one more issue, From my Webmonthview control I am calling the Apoointmentadd.aspx, where i am editing the appointment.
After I save the appointment, in my parent page where i have WeMonthView to be reloaded with the latest month that i have updated. But after reload, the parent page is showing current month.
How can i change the display of webmonthview to some future month without using Next navigation button?
Is there a way to change to a future month, without using the ActiveDayUtc property?
Chuck
Have you set the ActiveDayUtc on the WebScheduleInfo to the future month you want to display?
Changing the ActiveDayUtc will also change to a future month any other views sharing the same WebScheduleInfo. So if you have other views, then you may need the WebMonthView to use a different WebScheduleInfo from the others (the drawback here may be Activities have to be loaded by both WebScheduleInfos).
