Hi guys!
Are you aware that the WebCombo ( v9.2 ... the latest version ) has STOPPED working in v3.6 of Firefox which was just released ??? The control no longer fires the events for "SelectedIndexChanges" and the DoubleClick Event for the WebGrid has also stopped working ... the event simply won't fire any more !
It works perfectly in v3.5.8 though, and the latest IE
You should set this as HIGH PRIORITY stuff to fix
rgd,EE
Was this fix included in the recently released NetAdvantage 2010 Volume 2?
Well in that case you can always use the workaround mentioned in the previous post.
Correct, but because my license has expired, I am unable to download the SR. My company did not want to continue with Infragistics because of these errors.
To be honest, I don't think it is fair that we don't have the right to apply the SR, afterall, Infragistics created this problem by not following the roadmap of FireFox. So end of the story.
Infragistics has release a service release that addresses this problem.
I have applied it and it works perfectly..
Hi, a lot of people are going to suffer from this bug. I found in a post on this forum a workaround, I tested it and it solved my problem. Hopefully it's gone do the same for you.
http://community.infragistics.com/forums/p/36753/217075.aspx#218073
