95
ASP.NET WebHtmlEditor loses its value on submit
Entering text in a WebHtmlEditor control and clicking a submit button submits the form.  However, the value of WebHtmlEditor.Text is always empty, regardless of what was typed in the WebHtmlEditor.
- Add a WebHtmlEditor control to an ASPX page.
- Add a button to submit the form.
- Capture the WebHtmlEditor contents in the code-behind .cs file using WebHtmlEditor.Text
- Type text into the WebHtmlEditor and submit the form.
Placing a breakpoint on WebHtmlEditor.Text will show that the Text value is empty.
This result occurs both inside or outside of an UpdatePanel, so that is not the problem.
  • 95
    Verified Answer
    The data was being refreshed on postback, so the original value (which is blank) was being submitted.  Adding a postback check solved the problem.
    if (!Page.IsPostBack)
        RefreshData()
