Hello!
I am using the webtexteditor and it is connected to a regularexpressionvalidator control.
After the first postback, the validators javascript shecking stopsworking
Steps to reproduce:
1. write some letters in the textbox, like absdef
2. Press tab. you can now see that the validator is working.
3. write the number 1 in the textbox and press tab. the value seems to be ok.
4. Click the button to do a postback.
5. Enter the textbox and write some letters one more time. press tab. the validator doesn't complain
about the input this time...
why is this happening?
i have tested this exact case using an ordinary asp:textbox and it works...
thanks for your help!
/Henrik
Hi Henrik,
I looked at history of tfs and appears to me that fix should be included in latest service release for 9.2 and 10.1 (2010) versions.
Thanks!
Do you know if this issue is solved in the new release (2010), if I upgrade to that?
/H
You may find schedule of service releases at http://es.infragistics.com/support/default.aspx#ServiceReleases
do you have a date for that, approximately?
Thank you for a report.That issue was fixed few weeks ago. I expect that coming service releases will contain that fix.
