When there are many records in a grid and a scrollbar appears on the IE then if the mouse cursor is on the grid the mouse wheel does not work. If we move the mouse away from grid and somewhere else on the form then the mouse wheel works and we are able to scroll.
Could you please help.
Tahir
Hi Leadbeater,
I have tested your scenario with the latest service release - 11.1.20111.2064 under IE8 and IE9 and did not experience any issues with mouse-wheel scrolling. Attached is my working sample (which uses the Northwind DB).
In order to investigate this further, a sample reproducing the issue would be greatly appreciated.
Please do not hesitate to contact me if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://es.infragistics.com/support
Any ideas on this? I am still waiting...
In one of the previous releases this problem was fixed and I didn't have to use this script anymore. However, in 2011.1 this problem has reappeared.
Could you kindly have a look and see what is going on. I may have missed something but would like to know what.
Hello Alex,
Thank you, that works just fine.
Correction:
</form>
$IG.WebDataGrid.prototype._oldOnMouseWheel = $IG.WebDataGrid.prototype._onMouseWheel;
$IG.WebDataGrid.prototype._onMouseWheel = function(evnt)
if (this._container.scrollHeight <= this._container.clientHeight)
return;
this._oldOnMouseWheel(evnt);
</script>
</body>
</html>
