I have a simple web page with a single button that brings up a WebDialogWindow. This works fine !!!
Now try putting a WebDateChooser control in the WebDialogWindow. Note the code is :-
<head runat="server">
<title>Dialog Test</title>
dialog.show();
</script>
<body>
<form id="form1" runat="server">
<div>
<asp:ScriptManager ID="ScriptManager1" runat="server">
</asp:ScriptManager>
AutoSubmit="False">
<ClientSideEvents MouseDown="WebImageButton1_MouseDown" />
</igtxt:WebImageButton>
<cc1:WebDialogWindow ID="WebDialogWindow1" runat="server" Height="300px" Width="400px"
InitialLocation="Centered" Modal="true" WindowState="Hidden" StyleSetName="Default"
StyleSetPath="~/ig_res/">
<Header CaptionText="Dialog Test" CaptionAlignment="Center">
</Header>
<ContentPane>
<Template>
<igsch:WebDateChooser ID="WebDateChooser1" runat="server" Style="left:30px; top:30px;">
</Template>
</ContentPane>
</cc1:WebDialogWindow>
</div>
</body>
When I run this page in my browser, and click on the button, the WebDialogWindow appears with the blank (Null) WebDateChooser.
Now click on the drop down button to bring up the calendar section of the WebDateChooser, and nothing appears.
Close the WebDialogWindow, and lo and behold the calendar section is now visible !!!
Selecting the date causes the calendar to disappear.
Now again click the button to bring up the WebDialogWindow, and the WebDateChooser has the correct date that was selected above.
This interaction of dialog window and date selection is one which I would use a lot, but alas without a quick fix, looks like I will have to revert to using other controls.
Note I am using the latest 2008 V1 version of NetAdvantage, and VS 2008 (full version, not RTM etc).
Any idea why this is happening ?
Thank you for reporting an issue. That was fixed around March 2008. Please update NetAdvantage with latest hot fix.
the temporary fix worked for me but i'm curious whether there is a planned permanent fix for this and/or if it's been assigned a tracking number of some sort within infragistic's bug tracking database ? thanks
Hi Tony,
i have fix the problem with FF by changething the if(lidZ <= 99999) now the script is working for both IE and FF
function pageLoad(args){ $IG.DialogMoveBehavior.prototype._doZ= function(lid, elem, lidZ) { this._newZ = this._oldZ = $util.getStyleValue(null, 'zIndex', elem); if(!lidZ) lidZ = $util.toInt($util.getStyleValue(null, 'zIndex', lid), 0); if(lidZ <= 99999) { lid.style.zIndex = lidZ = 101; //z-index will default to 100 in a modal scenario } if($util.toInt(this._oldZ, 0) <= lidZ) { elem.style.zIndex = parseInt(this._newZ = lidZ + 1); } return lidZ; }; }
Thanx
$IG.DialogMoveBehavior.prototype._doZ=function(lid, elem, lidZ){ this._newZ = this._oldZ = $util.getStyleValue(null, 'zIndex', elem); if(!lidZ) lidZ = $util.toInt($util.getStyleValue(null, 'zIndex', lid), 0); if(lidZ < 10) lid.style.zIndex = lidZ = 100; //z-index will default to 100 in a modal scenario if($util.toInt(this._oldZ, 0) <= lidZ) elem.style.zIndex = this._newZ = lidZ + 1; return lidZ;};
this Script only work with IE, but not in FF, i have enabled Modal="True". but when Modal is not enable controls work fine. what is the fix for this script to work with FF
thnx
Thank you very much for your replay.
I already using trying have the code which one you sent to me. i copyed from your post only. but still its now working with my form. Im using content page, i have master page.
<asp:Content ID="Content1" ContentPlaceHolderID="ContentPlaceHolder1" Runat="Server">
<script language="javascript" type="text/javascript">
if(!lidZ)
if(lidZ < 10)
<ig:WebDialogWindow ID="MSG" runat="server" Height="352px" InitialLocation="Centered"
Modal="True" Style="line-height: normal " Width="518px" BackColor="White" Visible="False" >
<Header CaptionAlignment="Left" CaptionText="Delegation Details">
<CloseBox Visible="False" />
<ContentPane BackColor="White">
<div style="position: relative; text-align: center" align="center">
<br />
<TABLE style="WIDTH: 469px; height: 279px;"><TBODY><TR><TD style="WIDTH: 100px; font-weight: bold; font-size: 10pt; height: 26px;" align="left">Department</TD><TD colSpan=5 style="height: 26px" align="left"><asp:DropDownList id="cmbDepartment" runat="server" Width="311px"></asp:DropDownList></TD></TR><TR><TD style="WIDTH: 100px; HEIGHT: 23px; font-weight: bold; font-size: 10pt;" align="left">Division</TD><TD style="HEIGHT: 23px" colSpan=5 align="left"><asp:DropDownList id="cmbDivision" runat="server" Width="310px"></asp:DropDownList>
<asp:Label ID="ID" runat="server"></asp:Label></TD></TR><TR><TD style="WIDTH: 100px; HEIGHT: 23px; font-weight: bold; font-size: 10pt;" align="left">Delegate To</TD><TD style="HEIGHT: 23px" colSpan=5 align="left"><asp:DropDownList id="cmbDelegateTo" runat="server" Width="310px"></asp:DropDownList></TD></TR><TR><TD style="WIDTH: 100px; HEIGHT: 23px; font-weight: bold; font-size: 10pt;" align="left">Start Date</TD><TD style="HEIGHT: 23px" colSpan=5 align="left"><igsch:WebDateChooser id="txtStartDate" runat="server" BackColor="White">
<CalendarLayout Culture="English (United States)">
</CalendarLayout>
</igsch:WebDateChooser></TD></TR><TR><TD style="WIDTH: 100px; HEIGHT: 23px; font-weight: bold; font-size: 10pt;" align="left">End Date</TD><TD style="HEIGHT: 23px" colSpan=5 align="left"><igsch:WebDateChooser id="txtEndDate1" runat="server" BackColor="White" EnableAppStyling="True">
Comment(s)</TD><TD style="HEIGHT: 52px" colSpan=5 align="left"><asp:TextBox id="txtComment" runat="server" Height="53px" Width="306px" TextMode="MultiLine" MaxLength="255"></asp:TextBox></TD></TR><TR><TD style="WIDTH: 100px; font-weight: bold; font-size: 10pt; height: 34px;" align="left"></TD><TD colSpan=5 style="height: 34px" align="left">
<asp:Button ID="btnSave" runat="server" BackColor="White" ForeColor="#0000C0"
Text="Save" ToolTip="Please Click On Button To Update Changes." Width="61px" />
<asp:Button ID="btnClose" runat="server" BackColor="White" ForeColor="#0000C0" Text="Cancel"
ToolTip="Please Click on Button To Close window." Width="61px" /></TD></TR></TBODY></TABLE>
</div>
</ig:WebDialogWindow>
</asp:Content>
This is my code what im doing now. Please try to help me out from it.
Thanking you
