Hi, I'm using the following controls in my 9.2 application using the Harvest AppStyle:
<ig:WebDatePicker ID="dtStart" runat="server">
<ig:WebNumericEditor ID="nmTrack" runat="server" DataMode="Int"><Buttons SpinButtonsDisplay="OnRight"></Buttons></ig:WebNumericEditor>
The images (e.g. igmc_nextPress.gif, igte_lowerHover.gif, igte_CustomHover.gif) for the arrows/backgrounds are missing from the /ig_res/Harvest/images/ directory. Where can I download them?
Hi Alexsandr, Thank your feedback. I understand your frustrations. Currently we are trying to answer as many forum post as we can. In this particular situation we noticed this issue and we decide to update this forum post. We found that the issue was recently fixed and wanted to share it with all users facing the same issue.Currently Infragistics does not support the forums directly. They are peer-to-peer only.You can find more about our Support Policy here:http://es.infragistics.com/support/policies.aspx#SupportPoliciesPlease let me know if you have any further questions.Sincerely,DimiDeveloper Support Engineer, MCPD Infragistics, Inc.www.infragistics.com/support
You guys MUST be joking replying to this post a YEAR later and waiting for the next release of the software to make changes. This is not acceptable for any serious commercial software which wants to stay in business.
Hello ,
I tried to reproduce the issue with the latest service release of 10.3 version (10.3.20103.2105) and I was not able to.
I imported the Harverst styleset and all the described images persisted in the /ig_res/Harvest/images directory
Can you please check if you are able to replicate the issue with the last SR?
This service release is available under your account at the Infragistics Website.
To download the service release, log in to ‘My IG’ and select ‘Keys & Downloads’.
Select the appropriate tab for this product; then the license key.
The available service releases (Hot Fixes) should now be listed on the page.
Let me know if you are able to reproduce the behavior with the latest service release.
Thank you for reporting this issue, we will take a look and will try to resolve it for the next service release.
Thank you for using Infragistics forums!
Lubomir
Same issue with 2010.3
And, look a month later not a single replay form infragistics.
