125
Grid column and Column Headers are not visible.
I am using ultrawebtab and ultrawebgrid control ver 9.1.20091.2126.
I have multiple databases and i want to show data of each database in a webgrid.
I am using ultrawebtab control which shows data of different databases in different tabs.
I am using usercontrol which contains ultrawebgrid.
Following is the code to add tab at runtime and assign grid to that tab.
Infragistics.WebUI.UltraWebTab.Tab tab = new Infragistics.WebUI.UltraWebTab.Tab("KOALA2");
                        this.UltraWebTab1.Tabs.Add(tab);
                        tab.ContentPane.UserControlUrl = "WebUserControl.ascx";
                        WebUserControl UC1;
                        UC1 = (WebUserControl)tab.ContentPane.UserControl;
                        ugList  = (UltraWebGrid)UC1.FindControl("ugMachineList");
I have added column headers and i want to fix first two column of grid.
Following is the code in InitializeLayout event of grid.
e.Layout.StationaryMargins = StationaryMargins.Header;
e.Layout.UseFixedHeaders = true;
e.Layout.Bands[0].Columns.FromKey("SiteName").Header.Fixed = true; e.Layout.Bands[0].Columns.FromKey
("Machine/Brand").Header.Fixed = true;
But when i used UseFixedHeaders = true, in that case i cannot see the all headercolumn and grid column in second tab.
This code works well in first Tab but fails in second tab.
Please find attached the screenshot which itself explain the problem.
Please let me know if any other details are needed.
Please revert it ASAP.
Regards
Tab2.zip
