I would like to be able to add a row to the bottom of the grid but seem not to see a way to do this. The .add() method of the rows collection seems not to work.
Hi again,
Let me add something. I had the same need, so I created the row without any info in the non key fields so it looked like a blank new row was added. The problem is the user closes the browser and you don't get a chance to delete blank rows that were left.
I am assuming that you don't like the look of the row adding behavior with a botom alignment. I didn't like it either. That would get you closer to what you're looking for.
Ed
Not doable. Here's something from the docs.
What I would like to do is add a row, which appears at the bottom of the grid then the user can add the infomation in there. After which it can post back to the server. Is this not doable using this grid?
I would imagine that Autocrud cannot be false for this ajax call to work. With the webdatagrid, it posts the added row immediately. That functionality must be present in the grid itself.
This seems not to work. Could you post your grid definition? Here is mine:
="EXECUTION_STATUS">
="System.String">
="System.Int32">
="False">
="Text">
="nepSortOrder">
