571
WebDropDown control on Dotnetnuke not working
Hi
I am having some difficulty integrating Infragistic Controls onto a Dotnetnuke module that I am building for a DNN site. Here is the problem I am facing:
I am wanting to use the WebDropDown control and specifically the cascading drop down feature where a second dropdown items are loaded after the first one has been selected. Am am simply using the exact scenario as shown on the Infragistics samples that ship with the installation. To test what I wanted to do I first build a Webpage in a standard ASP.NET application using VS2008. It works absolutely fine in this scenario.
When I set up the same scenario using Dotnetnuke however nothing seems to happen after I select the first Dropdown. I have checked that the javascript function is loaded correctly into the page.
Could it be that there are javascript functions that come with the control that are not being registered on the page which are being registered when using a standard ASP.NET applications???
Any ideas would be very helpful
Many Regards
Andrew
