I have a dropdown templated column in my webdatagrid. This dropdown is bound to a sqldatasource and return a bit huge data, Nearly 3 thousand records.
My problem is whenever i do a asnypostback. i.e on virtual scroll,sorting,filtering etc... i get a blank error message on the screen that the script is causing the IE to run slow. I believe this is happening due to huge datainside the template dropdown. This works fine in FF but gives problem in IE6. Can anyone help me on this plz ?
<ig:TemplateDataField Key="ClientGroup"> <ItemTemplate> <ig:WebDropDown ID="ddlClient" runat="server" DataSourceID="sqldsClientGroupProvider" TextField="ClientGroup" ValueField="ClientGroup" EnableLoadOnDemand="True" EnablePaging="True" > <DropDownItemBinding TextField="ClientGroup" ValueField="ClientGroup" /> </ig:WebDropDown> </ItemTemplate> <Header Text="ClientGroup" /> </ig:TemplateDataField>
This has been a known performance issue that happens on postback, and has been resolved some time ago. I am sure if you upgrade the assemblies to a later version, it should work great.
Thank you,
Angel
