I upgraded from Version=9.1.20091.2101 to Version=9.1.20091.2126 in hopes that bug report #19238 was addressed. Now about half my WebDataGrids get an NullReferenceException when I try to sort or filter on a column. They worked fine using the exact same code and the exact same data using the older version.
Is any body else having this problem?
Hello,The fix is currently awaiting test. In the future you can ask for an update by sending a request through your case.You can find your cases by logging in on infragistics.com and selecting the "My IG" tab and then select "Support Requests from the drop down menu.Thank you,Stephani
Any progress on this case (CAS-37265-JASSON)? I don't know any place where I can check on a case number directly without Infragistics assistance.
I had my boss put in a support request as our license is tied to his Infragistics forum userid and it would not let me enter one. It is CAS-37265-JASSON.
I am sorry it has taken awhile for me to reply. The issue that you are experiencing is a bug, which is only present in the 9.1 volume. I have talked to our development support and they will be creating a case for you for this issue, and will contact you to let you know what the case number is.
Thank You,
Olga
I have been having almost the same problem. The checkbox in a template column makes me get "failed to load viewstate" exception. By me, it only happens when I have an editorprovider defined. I have a dev support case that's been escalated to development on this one. It's case 35333. I hope this will be of help. There's another post on this forum for the same issue as well.
My client has a true or false on their screen in place of a checkbox. Not exactly in line with my visions for the presentation layer.
Good luck,
Ed
