215
SelectedDateChanged event not calling when date is selected
Iam using Infragistics WebMonthCalendar control for displaying calendar.Here,Iam facing problem while calling SelectedDateChanged event through c#.net in Infragistics WebMonthCalendar.
Here is code
protected override void OnInit(EventArgs e)
        DropDownList.SelectedIndexChanged += new EventHandler(DropDownList_SelectedIndexChanged);
      WebMonthCalendar.SelectedDateChanged += new CalendarSelectedDateChangedEventHandler(WebMonthCalendar_SelectedDateChanged);
        base.OnInit(e);
protected void WebMonthCalendar_SelectedDateChanged (object sender, CalendarSelectedDateChangedEventArgs e)
        //Code
protected void ddCalCulture_SelectedIndexChanged(object sender, EventArgs e)
       //code
Dropdown SelectedIndexChanged event is working fine.However in infrgistics,it  was not calling SelectedDateChanged event when Iam selecting the dates.
I have already tried replacing protected with Public,private/void.But No Luck.
Please help in this case.
  • 24497
    Suggested Answer
    I tested your codes and they worked as expected.
    However, to see a server event you need a postback. You may drop a Button on page, change selection and click that button to submit. If you want automatic submit on selection change, then you should enable AutoPostBackFlags.SelectionChanged (in designer or in codes). Below is example.
      this.WebMonthCalendar1.AutoPostBackFlags.SelectionChanged = Infragistics.Web.UI.AutoPostBackFlag.On;
      this.WebMonthCalendar1.SelectedDateChanged += new CalendarSelectedDateChangedEventHandler(WebMonthCalendar_SelectedDateChanged);
      base.OnInit(e);
