in one of our projects we are using the WebDataGrid with a custom PagerTemplate as our customers wishes some functions to save the grid settings. Therefor the Pager control contains a menu, which is realized using the HoverMenuExtender of the AjaxControlToolkit.
Everything worked fine until we decided to set the PagerAppearance from Bottom to Both. The hover menu is only triggered by the upper pager control. A quick check of the HTML source shows that the ClientIDs of the pager control are identical for both the upper and the lower pager.
This does not just lead to problems with the HoverMenuExtender but to serious problems processing a postback.
Attached to this post you can find a very small example that shows the problem described above. You'll probably have to add the AjaxControlToolkit binary which I removed to reduce the upload size.
I'd be very glad if you could offer us some help.
Best regards
Philipp
Hi Philipp,
That bug was fixed months ago and now both pagers render unique IDs. You should not experience any issues with the latest service release.
