I'm binding to a WebDataGrid but can't seem to hide the columns because after the bind they aren't available in the collection.
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load If Not Page.IsPostBack Then Dim o As New clsFitter clsMySQL.Conns.LoadConnections() clsMySQL.CurrentUser = New clsUser clsMySQL.CurrentUser.LoadUser(5) dgCurrent.DataSource = o.GetCurrentJobs LoadTheseColumns(dgCurrent, "JobRef(Job #),Address(Address)") End If End Sub Private Sub LoadTheseColumns(ByRef dg As GridControls.WebDataGrid, ByVal sColumns As String) Dim iCol As Integer Dim ColumnName, ColumnHeader As String Dim arrColumn() As String For Each col As GridControls.GridField In dg.Columns col.Hidden = True Next For Each col As GridControls.GridField In dg.Columns arrColumn = Split(sColumns, ",") For iCol = 0 To arrColumn.GetUpperBound(0) If InStr(arrColumn(iCol), "(", CompareMethod.Text) > 0 Then ColumnName = Mid(arrColumn(iCol), 1, InStr(arrColumn(iCol), "(", CompareMethod.Text) - 1) Dim iStart, iLen As Integer iStart = InStr(arrColumn(iCol), "(", CompareMethod.Text) + 1 iLen = Len(arrColumn(iCol)) ColumnHeader = Mid(arrColumn(iCol), iStart, iLen - iStart) Else ColumnName = arrColumn(iCol) ColumnHeader = arrColumn(iCol) End If dg.Columns(ColumnName).Hidden = False dg.Columns(ColumnName).Header.Text = ColumnHeader dg.Columns(ColumnName).VisibleIndex = iCol Next Next End Sub
In the code above when I get to dg.Columns the count is zero. When the page displays all columns are however shown. I've also tried the above referring to dgCurrent(the grid) directly rather than byref. Also with AutoGenerateColumns true and false...
The grid.rows.count is 44 so the data is being loaded.
Am I missing something obvious??
The behavior you see is correct. To configure columns in this fashion requires that the columns be defined, rather than auto-generated. Alex comments about this in the following post:http://forums.infragistics.com/forums/p/30805/171690.aspx#171690
