660
Client side selection of the WebDropDown value and updating of the control text.
I must be doing something wrong since for the asp.net DropDownList, I only needed 1 line of code.
ddlX.options[i].selected = true;
  Converting over to an ig control has been a lot of work.  1st my DropDowns are in a WebDialogWindow that starts off hidden which messes up the z-axis so I run the following:
function ddlInitialize(sender, args) {
try
sender.behavior.set_zIndex(200000);
catch
(err) {
alert(
'unable to initialize drop down' + err.description);
Then, in order to change the current selection I have to run the following routines:
function ddlClearSelection(ddl) {
for (var ix = 0; ix < ddl.get_items().get_length(); ix++) {
var item = ddl.get_items().getItem(ix);
if (item != null) {
item.unselect();
item.inactivate();
return false;
function ddlSelect(ddl, indx) {
ddlClearSelection(ddl);
ddl.set_selectedItemIndex(indx);
ddl.set_activeItemIndex(indx);
ddl.set_currentValue(ddl.get_items().getItem(indx).get_text(),
true);
ddl.get_items().getItem(indx).select();
ddl.get_items().getItem(indx).activate();
ddl._elements.Input.value = ddl.get_items().getItem(indx).get_text();
The markup for one of the WebDropDowns is as follows:
ig:WebDropDown ID="DropDownListAccountGroup2" runat="server" Width="200px" DropDownAnimationDuration="100" DisplayMode="DropDownList" EnableDropDownAsChild="False">
<ClientEvents Initialize="ddlInitialize" />
<ClientEvents SelectionChanged="ddlAcctGrpChng2" />
</ig:WebDropDown>
