for the database, is it ASP.NET infragistics can only connect to SQL Server? can it connect to MySQL?
i'm now using MySQL to store all my data. how can i connect ASP.NET to MySQL so that i can use webdatagrid to display my data??
Our ASP.NET controls (including WebGrid, WebDataGrid, and WebHierarchicalDataGrid) are not specific to any database server. You use data objects, such as SqlDataSource, as the data source for any of these grids. It is then the responsibility of the data source to communicate with the database, and not the grid.
I don't myself have familiarity with MySQL. Even so, if you can pull the MySQL data into .NET using a DataSource object, you can bind it to WebDataGrid.
