Ok, first I am a noob to ASP. I took over a project from a guy that left. I looked at this for a day so any help is appreciated.
My problem is that I only see a red X instead instead of the drop down image.
I see the file I would expect in ig_res\Nautilus\images\igdd_DropDownButton.png. inside of my project.
DropDowns on the main page look fine. What does not look right is the drop downs on a the new window that opens.
<ig:WebDropDown ID="ddlDesc" runat="server" DropDownAnimationType="Linear"
DropDownContainerHeight="0px" DropDownContainerMaxHeight="0px"
DropDownContainerWidth="0px" EnableDropDownAsChild="True"
MultipleSelectionType="Checkbox" PageSize="0" Width="200px" TextField="Text"
ValueField="Value" >
<ClientEvents SelectionChanged=DdlDesc_IndexChanged_ />
</ig:WebDropDown>
Web.config
infragistics.web javaScriptDirectory="~/JavaScript" imageDirectory="~/ig_images" cssDirectory="~/ig_res"/>
My fault.
It turns out the ig_res folder was not included in the Websetup project. I'm not used to web projects - I normally do web sites. I'm still trying to figure out what is automatically included or detected in a Websetup and what is not (and how to add what is not).
I added the ig_res tree and all files to the Websetup and the dropdowns display properly now.
thanks!
Could you check what URL it is looking for for the image that is not displayed? your resources (ig_res folder) must be placed in that location, or you should ovverride it in web.config.
Hope it helps. Thanks,
Angel
I'm in about the same boat on this.
I've added a webdropdown to my page. I bound it to my SQLDatasource. I set the text and value fields. I have not done anything re: styling. or changed my web.config.
My application already has the appropriate DLLs, references, and scripts included as I use UltraWebGrids in it w/no problem.
Running my project in debug mode in VS2008, the webdropdown looks fine and performs properly.
After building my project and websetup and installing on my web server, I get a red X box where the downarrow should be. I can click on that and the list drops down and functions (although it abviously has display/style issues - it looks more like a stack of hyperlinks in the webserver).
I'm assuming I missed something basic?
Switching it to default does not make a difference.
Hi Joe,
Could you try with a different StyleSet , like "Default" or "Appletini" ?
