The frame of the ImageViewer doesn't appears. It loads all the images correctly.
When I I apply a style, in Designer , I can see it changes but when I run it on the browser it only shows the Next and Previous buttons with the styled changed. The basic isn`t even working, it only shows the buttons.
I'm posting a screen shot of the imagen viewer.
Thanks!
Gaby!
Could you make sure you have the styles in your project, and that StyleSetPath is pointing to the correct location ?
For example if StyleSetPath (either in the control, or in web.config) is set to "~/ig_res", make sure that such folder exists, and has all stylesets.
Angel
