1510
How to Export data from Grid into Excel sheet ?
Is this the correct way to Export the data ?
It's *working* ... but do I need this session stuff to get the data from the Grid???
If I don't use it ... the _ugTransactions.Rows.Count is just 0
How would you do it ?    This is how I'm doing it now:
UltraWebGridExcelExporter1.ExportMode = Infragistics.WebUI.UltraWebGrid.ExcelExport.ExportMode.Download;
_transactions = (SortableCollection<AKTransactionTrack>)Session["dataFromGrid"];
_ugTransactions.DataSource = _transactions;
_ugTransactions.DataBind();
//int check = _ugTransactions.Rows.Count;
UltraWebGridExcelExporter1.Export(_ugTransactions);
I've already binded the Datasource to the Grid BEFORE using this code ( so the Grid should have data when I push the "Export" button but stil it's empty ??? ( I'm coming from Windows FORMS, not asp.net ... so I thought of using the session stuff ... probably it's wrong ??? ):
protected void _btnSearch_Click(object sender, EventArgs e)
            string bankanumer = _tbBankanumer.Text.Trim();
            string hofudbok = _tbHofudbok.Text.Trim();
            string reikningsnumer = _tbReikningur.Text.Trim();
            _transactions = TrackingBusiness.GetAllAKTransactionTracksBySearchCriteria(bankanumer, hofudbok, reikningsnumer);
            Session.Add("dataFromGrid", _transactions);
