Hello
is it possible to transform the Item Label Format of ColumnChart?:
i want to transform for example 1000 to 1.000, 1000000 to 1.000.000 etc...
so tausend delimiter symbol
Thank for helping
Thanks Max, now it work great.
If you only display integer values on the axis you can use DATA_VALUE:n0. This will not display any decimal places. We use standard string formatting for the numeric labels. You can read about it in more detail here:http://msdn.microsoft.com/en-us/library/dwhawy9k(VS.71).aspx
Hi Max,
This work fine just one problem i dont want for Dava_value < 1000 the comma (58 is now 58,00 etc...)
thanks
You can set chart.Axis.Y.Labels.ItemFormatString = "<DATA_VALUE:n>"
