I have multiple user control UC1,UC2.UC2 have the controls Dayview and scheduleinfo and LodingData method.This method loads the data from Db depends on passing date.The data passed from UC1.Am use the UC1 and calendar control in homePage.I need to If i select the single date the UC1 add the UC2 dynamically with passing date and loading the db value.suppose i select the multiple date the UC1 adds the UC2 multiple times with the two different selected date.That is the First UC2 loads the 12.2.2009 data,and the second UC2 loads the 13.2.2009 data dynamically.How to do that.I add the user controls dynamically but it not loads the data.how to load the that.
