595
CRITICAL BUG: Row data does not update in an AutoCRUD scenario.
I have posted this under My IG with the case number: CAS-29509-U12QD8, however this is a pretty major bug, so I thought I'd post here to in order to hopefully get a fast answer.
When editing two cells on the same row and then clicking away from the second cell, only the second change will be persisted on PostBack.
Please perform the following on your Automatic CRUD for Custom Collections sample.
  • Click on any editable cell
  • Make a change
  • Click on a different cell on the same row
  • Make a change
  • Click a different row
  • Click Save Changes
Only the second change on the row will be persisted. The first change will be lost.
However, if you press enter after the second edit both changes will go though. Or if you click Save Changes BEFORE leaving the editing mode on the second cell, the changes will also go though.
