100
Unable to local license assembly.
I evaluvating the Netadvantage Asp.Net 7. Our team has 4 member 2 working on the UI and 2 working on the middle tier. We also have a build machine which checks the source control for changes and does a build on any changes and runs the unit tests. We dont have Infragistics installed on the build machine so now the build on the machine fails.
Exception occurred creating type 'Infragistics.WebUI.UltraWebGrid.UltraWebGrid, Infragistics2.WebUI.UltraWebGrid.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' System.ComponentModel.LicenseException: Unable to locate license assembly." dir="Properties" name="licenses.licx.
Also the 2 middle tier devlopers cant do the build either since they dont have infragistics installed on their machine.
Is there some way to get around this without installing infragistics on the build machine. I have all the refereced dlls in the project itself.  Buying another license just to do build in my opinion is pointless.
Thanks.
  • 1912
    Search the entire forums on the term 'build server' and you should return 7 items.
    If those don't supply the information you're looking for then please contact Developer Support for additional assistance.
