1004
WebChart: Problem with Tooltips
hello Infragistics community,
I have a Problem with Tooltips if i use a foreach instruction in asp.net:
1) if i write simply like this: <% Html.RenderPartial("HBarChart"); %> it work perfect but
2)if i write it like that: <% foreach (var Chart in Model.Chart) {%>
<% Html.RenderPartial(Chart.ToString());%> <% } %> it didn't work. what can be actually the Problem?
3) or if a add a second <% Html.RenderPartial("PieChart"); %> it didn't work too.
Thanks You very much for your Reply
  • 28496
    possibly there is a conflict generating html elements with the same id?  i'm not really sure since i can't see the details of your implementation.
    do you have a sample project i could look at?  or if not, could you provide details on the tooltip errors, including any error messages you are seeing?
