Hi
If I have appointment starting 9:44 and finishing 10:44 I CANNOT drag this appt. to 9:00 or 10:00 or 11:00. Only to 9:14, 9:44, 10:14, 10:44.
So, sliding works incorrectly
Is there workaround?
Thank you for help in advance!
Hello zhornyk,
The behavior you are seeing is the expected behavior of the control. In this scenario you are able to drag your activity to a different time slot on the day view calendar but the logic requires that the possible start times be at 30 minute intervals.
So since your original activity started at 9:44, the activity can be moved within 30 minutes intervals. This would be 10:14; 10:44; 11:14, etc.
Please let me know if you need any additional assistance regarding this matter.
Hi zhornyk,
I wanted to check back with you to see if you had resolved this problem, or if you are still in need of assistance regarding this matter.
