I need asp.net tree view trial version control with right click option for move, merge, delete and add.
Is it available such a functionality in this tree view.
You can find context menu example here:
http://samples.infragistics.com/2009.2/WebFeatureBrowser/contents.aspx?showCode=true&t=WebMenu/menupopup/MenuPopup.aspx~srcview.aspx?path=../WebFeatureBrowserVB/WebMenu/menupopup/MenuPopup.src~srcview.aspx?path=WebMenu/menupopup/MenuPopup.src
Is there an example of this anywhere?
Right now the WebDataTree is not supporting add, move and remove on the client.
However you can combine WebDataTree and WebDataMenu and show a context menu on a right mouse click. Than you can postback and modify the tree on the server.
