Hi All,
Am using Web slider control how to i use value chaged event its not fired on value chage...
please Help Any one..
It very urgent...
Thanks.....
Regards
Rajan.
Thanks Again Viktor,
I used update panel, for this control..little more faster than before.. But still page refreshed..
Hi SundaraRajan,
The AJAX based controls are not compatible with WARP (or UltraWebTab with async features), because they use different/parallel script managers. They can be used only side by side: no AJAX controls should be located in WARP. The UpdatePanel should be used instead.
Thanks Viktor,
Now Its working. but out of WARPControl not support this control.. When its(slider) call server Event
total page post back action performed why? I am using this control for data table filtering. please
Advice me.
Thanks.
SundaraRajan.C
Hi Rajan,
To start with you may try to test following.
<script type="text/javascript">function valueChanged(slider, eventArgs){ var tb1 = $get('<%=TextBox1.ClientID%>'); if(tb1) tb1.value = eventArgs.get_newValue();}</script><asp:ScriptManager ID="ScriptManager1" runat="server" /><ig:WebSlider ID="WebSlider1" runat="server"> <ClientEvents ValueChanged="valueChanged" /></ig:WebSlider><asp:TextBox ID="TextBox1" runat="server"></asp:TextBox>
