can you give an example of an hierarchical ultrawebgrid with data persisting?
using:
sqldatasource, webhierarchicalDataSrouce, DaD framework
Thanks.
It has been a while since you have made your post, in case you still need of support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So after my research on this questions I am attaching some valuable links that with information around this and examples how this functionality to be implemented.
Here is a sample using D&D with UltraWebGrid:
http://download.infragistics.com/users/skim/WebGridusingDragandDrop.zip
This articles here introducing Drag and Drop Framework:
http://community.infragistics.com/aspnet/articles/introduction-to-the-infragistics-web-drag-and-drop-framework.aspx
Here is an example with binding to an SqlDataSource:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.1/CLR4.0/html/WebGrid_Binding_WebGrid_To_SQL_Data_Source.html
Here is an example with binding to an WebHierarchicalDataSource
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.1/CLR4.0/html/WebGrid_Binding_WebGrid_to_a_WebHierarchicalDataSource.html
We have created a new framework that can be used to persist grid data.
For more information about this refer to this link:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Infragistics4.WebUI.UltraWebGrid.v11.1~Infragistics.WebUI.UltraWebGrid.UltraWebGrid~AddRow_EV.html
and also you can find live samples here:
http://samples.infragistics.com/aspnet/ComponentOverview.aspx?cn=persistence-framework
I hope this information is helpful
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
http://es.infragistics.com/support
