WebSplitter1.Panes[0].Collapsed = true
If this is executed in the page load event it works, but it does not work from a button click event.
What am I missing.
I have a ultrawebtree that loads a user control into the bottom pane (update panel) of a horizontal splitter bar. For this particular control I want to collapse (top) splitter bar.
I execute WebSplitter1.Panes[0].Collapsed = true in the same event that loads the usercontrol (LoadControl). The control loads just fine but the splitter bar does nto collapse. What am I missing?
HI,
I am assuming you are doing this on the Server_Side - then make sure you have Your AutoPostBackFlags set properly.
Here is a help link:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/Infragistics2.Web.v8.3~Infragistics.Web.UI.LayoutControls.WebSplitter~AutoPostBackFlags.html
I wrote a small applicaton that will collapse the pane on a button-click.
Here is my aspx page:
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
<%@ Register assembly="Infragistics2.Web.v9.1, Version=9.1.20091.2015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.LayoutControls" tagprefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title>Untitled Page</title> <script type="text/javascript"> function Collapsed(sender, splitargs){ debugger; } function Expanded(sender, splitargs) { debugger; } </script>
</head><body> <form id="form1" runat="server"> <asp:ScriptManager ID="ScriptManager1" runat="server" /> <div> <ig:WebSplitter ID="WebSplitter1" runat="server" Height="200px" oncollapsed="WebSplitter1_Collapsed" onexpanded="WebSplitter1_Expanded" Width="300px"> <AutoPostBackFlags Collapsed="On" Expanded="On" /> <panes> <ig:SplitterPane runat="server" CollapsedDirection="NextPane"> </ig:SplitterPane> <ig:SplitterPane runat="server" CollapsedDirection="NextPane"> </ig:SplitterPane> </panes> <ClientEvents Collapsed="Collapsed" Expanded="Expanded" /> </ig:WebSplitter> </div> <asp:Button ID="Button1" runat="server" onclick="Button1_Click" Text="Button" /> </form></body></html>
Here is my Code_Behind:
using System;using System.Data;using System.Configuration;using System.Web;using System.Web.Security;using System.Web.UI;using System.Web.UI.WebControls;using System.Web.UI.WebControls.WebParts;using System.Web.UI.HtmlControls;
public partial class _Default : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) {
} protected void WebSplitter1_Collapsed(object sender, Infragistics.Web.UI.LayoutControls.SplitterPaneCollapsedEventArgs e) {
} protected void WebSplitter1_Expanded(object sender, Infragistics.Web.UI.LayoutControls.SplitterPaneExpandedEventArgs e) {
} protected void Button1_Click(object sender, EventArgs e) { WebSplitter1.Panes[0].Collapsed = true; }}
