I learned a lot from these forums, thanks guys. I have another one here, must be a way to do it, but the poor online documentation doesn't tell me how. Argh.
The scenario is this:
In my WebDataGrid, I have a templated field that contains a dropdownlist. In the javascript onchange event of this dropdownlist, I look at the value the user chose. Depending on this value, I need to be able to make a BoundField in the current row ReadOnly.
In a different posting, someone mentioned that you have to set_cancel within the EnteringEditMode event in order to make it read-only. But I need to set the cancellation of it dynamically, in javascript. I was able to use the CSOM to get the Any advice? Let me know if I'm not clear enough.
Thanks guys!
Would you share how it works? Thanks.
Nevermind, i figured it out.
