How can I export a bitmap graphic to a spreadsheet?
Hello Currie,
This issue is resolved in the latest service release for Infragistics 2013 Volume 2 as of the date of this post. It is also resolved in Infragistics 2014 Volume 1.
Thank you for your response.
I also reproduced the issue when I made the modification you described. I have submitted this issue to our developers and I've created CAS-131957-S4Z5N0 to track the issue.
I have run into this same problem. I downloaded the sample you provided, changed the Format to WorkbookFormat.Excel97to2003, and I get the Null Reference Exception. I tried it with both 13.1 and 13.2. Any suggested workarounds?
Currie
I created the attached sample using 12.1, and I do not get any errors. You might want to check that the image actually exists in the folder you're trying to load it from.
Please let me know if my sample helps to resolve this issue.
It's possible a regression has been introduced. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
