Hi
I have a chart that I can add comments to when a data point is clicked on, and they are show as tooltips over the datapoint.
I want to be able to highlight these datapoints that have a comment.
I have the following code so far in the FileSceneGraph event:
foreach (Primitive p in e.SceneGraph)
if (p.GetType() == typeof(Polyline))
foreach (DataPoint dp in ((Polyline)p).points)
if (dp.DataPoint != null)
//Get comments
if (comments != null)
BoxAnnotation baX = new BoxAnnotation();
baX.Text = "POINT";
baX.Location.Type = LocationType.Pixels;
baX.Border.Color = Color.White;
baX.Location.ValueX = dp.point.X;
baX.Location.ValueY = dp.point.Y;
ucProductBurndown.Annotations.Add(baX);
The annotation does not appear on the graph.
Is there a way to highlight the datapoint?
You need to add the annotations when you create the chart. You can try the following code:
protected void Page_Load(object sender, EventArgs e)
this.UltraChart1.ChartType = Infragistics.UltraChart.Shared.Styles.ChartType.LineChart;
this.UltraChart1.DataSource = DemoTable.Table();
this.UltraChart1.DataBind();
CalloutAnnotation annotation = new CalloutAnnotation();
annotation.Location.Type = Infragistics.UltraChart.Shared.Styles.LocationType.RowColumn;
annotation.Text = "Annotation";
annotation.Location.Row = 0;
annotation.Location.Column = 1;
this.UltraChart1.Annotations.Add(annotation);
