85
How do I Update a WebTextEdit Box with Slider Value Changed
I have put a small sample together to work with WebTextEdit Boxes and WebSliders.  I can change the value of the slider when the text box changes but I am not able to change the value of the WebTextEdit box when the slider value has changed.
What am I doing wrong?  How do I access the text Edit Box from the slider call back.?
 function wceNum1_TextChanged(oEdit, newText, oEvent) {
 //Add code to handle your event here.//Get Current Value
 var num1 = igedit_getById("wceNum1");
 var val1 = num1.getValue();
 // Update Slider Value
 var slider = $find("<%= WebSlider1.ClientID %>");
 slider.set_value(val1);
 function SliderChanged(sender, e) {
 var myval = sender.get_value();
 //Update Num1 with value of slider
 var mynum1 = $find("<%= wceNum1.ClientID %>");
mynum1.setValue(myval);
 // HTML CODE
<asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager>
 <igtxt:WebCurrencyEdit ID="wceNum1" runat="server" MaxValue="1000" MinValue="1"
 ValueText="50"> <SpinButtons Delta="10" Display="OnRight" />
 <ClientSideEvents TextChanged="wceNum1_TextChanged" />
 </igtxt:WebCurrencyEdit>
 <br />
  <cc1:WebSlider ID="WebSlider1" runat="server" MaxValueAsString="100" MinValueAsString="1">
<ClientEvents ValueChanged="SliderChanged" />
 </cc1:WebSlider>
  • 24497
    Suggested Answer
    To get reference to javascript object of WebNumericEdit, the igedit_getById should be used. So, in function SliderChanged you may fix it by
    var mynum1 = igedit_getById("<%= wceNum1.ClientID %>");
    Note: In function wceNum1_TextChanged, there is no need to use igedit_getById('wceNum1'), because the first param oEdit is already reference to that object. You may use
    slider.set_value(oEdit.getValue());
