If I put 2 simple numeric series on a web chart where the data doesn't quite match up, it doesn't render the way I'd expect.
ASPX:
<igchart:UltraChart ID="UltraChart1" runat="server" BackgroundImageFileName="" BorderColor="Black" BorderWidth="0px" Version="9.1"> </igchart:UltraChart>
Code Behind:
protected void Page_Load(object sender, EventArgs e){ NumericSeries s1 = new NumericSeries(); s1.Points.Add(new NumericDataPoint() { Value = 50, Label = "Mark" }); s1.Points.Add(new NumericDataPoint() { Value = 40, Label = "Sue" }); NumericSeries s2 = new NumericSeries(); s2.Points.Add(new NumericDataPoint() { Value = 10, Label = "Mark" }); s2.Points.Add(new NumericDataPoint() { Value = 23, Label = "Bob" }); s2.Points.Add(new NumericDataPoint() { Value = 15, Label = "Joe" }); this.UltraChart1.Series.Add(s1); this.UltraChart1.Series.Add(s2); }
I would expect to see 4 clusters of columns for Mark , Sue, Bob and Joe. With Mark having data for both series, and the rest only for 1 or the other.
Instead, I get:Mark, Sue, <BLANK>, Mark, Bob.
So, I get only 2 values of each series written. Joe is ignored. And the values aren't clustered by the labels. Is there a way I can get what I'm looking for?
Thanks Teodor. I switched my code to massage the data into the format the charts are expecting and things are working.
You need to add 4 series. You can try:
s1.Label = "Mark";
s1.Points.Add(new NumericDataPoint() { Value = 50, Label = "1" });
s1.Points.Add(new NumericDataPoint() { Value = 10, Label = "2" });
s2.Label = "Bob";
s2.Points.Add(new NumericDataPoint() { Value = 23, Label = "1" });
s2.Points.Add(new NumericDataPoint() { Value = 0, Label = "", Empty=true });
NumericSeries s3 = new NumericSeries();
s3.Label = "Sue";
s3.Points.Add(new NumericDataPoint() { Value = 40, Label = "1" });
s3.Points.Add(new NumericDataPoint() { Value = 0, Label = "", Empty = true });
NumericSeries s4 = new NumericSeries();
s4.Label = "Joe";
s4.Points.Add(new NumericDataPoint() { Value = 15, Label = "1" });
s4.Points.Add(new NumericDataPoint() { Value = 0, Label = "", Empty = true });
this.UltraChart1.Series.Add(s3);
this.UltraChart1.Series.Add(s4);
this.UltraChart1.Data.ZeroAligned = true;
