105
Add Title to pdf
I have webgrid that I populate with a csla data source  and export to pdf using UltraWebGridDocumentExporter. I try to add a title to the pdf through the BeginExport event of the UltraWebGridDocumentExporter. This event doesnlt seem to be firing. following is the code. Not sure what I am missing:
The End Export event fires but doesnlt seem to add the title as well
BtnRunReport_Click
UltraWebGridDocumentExporter1.DownloadName = "Best Scores";
UltraWebGridDocumentExporter1.ExportMode = Infragistics.WebUI.UltraWebGrid.Exporter.ExportMode.InBrowser;
UltraWebGridDocumentExporter1.Format = FileFormat.PDF;
UltraWebGridDocumentExporter1.Export(this.uwgReportGrid);
protected void UltraWebGridDocumentExporter1_BeginExport(object sender, Infragistics.WebUI.UltraWebGrid.DocumentExport.DocumentExportEventArgs e)
e.Report.Info.Title = "Best Scores";
protected void UltraWebGridDocumentExporter1_EndExport(object sender, Infragistics.WebUI.UltraWebGrid.DocumentExport.EndExportEventArgs e)
 I alterbatively tried this code in the BeginExport event:
Infragistics.Documents.Report.Section.ISectionHeader _Header = e.Section.AddHeader();
Infragistics.Documents.Report.Text.IText _Title = _Header.AddText(0, 0);
_Title.Caption = "Best Scores";
Himgauri
