Hello
there is a sample page wich shows how to work with webSchedule .
on "Full Page Sample" the code of page WebScheduleInfo.aspx is missing.
(the code there is only of "Login" page
Wher can I get this code?
Tis is my first intruduction to web schedule,
any help how to get started with this will be appreciated
Great! That solves my questions. Thanks much for your help.
*EDIT*
Sorry, for the n00bishness, but my recurrences don't show up on the calendar unless I make it a regular appointment first.
*EDIT #2*
Nevermind, it was due to a custom "Show Time As" field I was using
1) You can change a particular appointment in a recurrence wihtout messing up the other appontments.
2) there is a property off of the WebScheduleInfo called EnabledRecurringActivities - set it to true
Here is the help link:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/Infragistics2.WebUI.WebSchedule.v8.3~Infragistics.WebUI.WebSchedule.WebScheduleInfo~EnableRecurringActivities.html
Thanks.
In that case, I have two questions:
1-Can someone move a particular appointment in a recurrence without messing up the others?
2-Recurrences aren't enabled on our site, but we can't find where to turn them on -- where is that stored? **acutally, technically they appear for a split second when opening an appointment, but then they'll disappear and the rest of the controls are moved over.
HI,
Here is a good help link on getting startedhttp://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/WebSchedule_Getting_Started_with_WebSchedule_Controls_and_Components.html
