804
I lost my style
Hi all,
Environment: Windows Vista Ultimate, Visual Studio 2008, Net Advantage ASP.net
I have two questions.
First, I already put the officeBlue2007 style in my project, I run it for the first time. Works great, after I wanted to put my own design style. So I go in visual studio->tools->application styling configuration->import style.
Naturally, my style didn't work AND when I wanted to put my old style(officeBlue2007).....it didn't work too....
So can you help me?
-Gabriel
  • 28407
    HI,
     Check your solution explorer and make sure you have Ig_res folder with the Office2007blue sub folder.
     To change your styling back to Office2007blue.
     Bring your website into Visual Studio 2007
     Click on Tools
     Click on Application Styling configuration - this brings up the NetAdvantage Application Styling Config dialog
     make sure enabled application styling is check off
    Select Application StyleSet - this  drop down should have Office2007 -
     if it does - selected it - then click apply and ok
     else (office2007 not in the drop down )
     then click import stylesets
     select office 2007blue - and click "import selected"
     go back to the dropdown  select application styleset and select office2007blue- then click apply and click ok
