80
Object reference not set problem - WebDialogWindow
Hi All,
We are using WebDialogWindow in one of our asp.net projects. The website loads properly on IE7, but with IE6 it results in a object reference not set exception.
The stack trace is:
  at Infragistics.Web.UI.Framework.AppStyling.AppStylingManager.ResolveUrlPath(String urlPath, Control control)
   at Infragistics.Web.UI.Framework.AppStyling.StyleBot.GetAppStylePath(Boolean css)
   at Infragistics.Web.UI.Framework.AppStyling.StyleBot.get_FullStyleSheetPath()
   at Infragistics.Web.UI.Framework.AppStyling.StyleBot.RegisterCssLinkFiles()
   at Infragistics.Web.UI.Framework.AppStyling.StyleBot.HandleInitializeStyles()
   at Infragistics.Web.UI.Framework.RunBot.InitializeStyles()
   at Infragistics.Web.UI.Framework.AppStyling.CssBuilder.OnPreRender(Control control)
   at Infragistics.Web.UI.Framework.AppStyling.StyleBot.HandlePreRender()
   at Infragistics.Web.UI.Framework.ControlMain.OnPreRender(EventArgs e)
   at Infragistics.Web.UI.LayoutControls.WebDialogWindow.OnPreRender(EventArgs e)
   at System.Web.UI.Control.PreRenderRecursiveInternal()
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
  • 24497
    Thank you for finding a problem. I do not rememer if anybody reported similar and I can not reproduce that. Can you build a simple aspx to reproduce it and attach to this thread (Options tab) or better submit a bug report.
