I populate a grid with strings and numerical data. I want the columns containing numerical data to be right aligned.
tbody.igg_Item tr td.ar{ text-align : right;}
no problem all my numerical data is right aligned.
However how can I right align the corresponding header text?
The Header object does not contain a CssClass property?
I know this is an old post, but I'd like to point out that as of 2009.2, each column's Header and Footer now have an assignable CssClass property. Problem solved - none of the above workarounds are necessary any more.
If it helps anyone, I did this with a hack-y Javascript solution that sounds complicated but is pretty easy once you've got the main script in a shared .js somewhere.
Steps:
function gridCallback() { }
function gridCallback() { alignWebDataGridHeaders("right", "CashItemId", "PaymentAmount", "Rent", "Difference"); }
The first parameter is the desired alignment, and the other parameters are a variable-length list of column key names. You can call the function more than once for different alignments.
<style type="text/css"> .divdetail th { padding-right: 8px; } </style>
The shared script iterates over all th elements in the page and looks for the id pattern used by Infragistics (Example: id=":1732066971.12:adr:1:idx:1:key:RentAmount"). It parses out the key (e.g. RentAmount) and then matches it against the column key list you've passed in. It sets the alignment if it finds a match.
//Gets the column key from an Infragistics th tag's id, usually something like id=":1732066971.12:adr:1:idx:1:key:RentAmount"function keyFromHeaderId(id) { var keyIndex = id.indexOf("key:", 0); if ((keyIndex > -1) && (id.length > keyIndex + 3)) return id.substring(keyIndex + 4, id.length);}//aligns a list of WebDataGrid headers. First arg is "left" etc. and then //just pass a comma list of header keys.function alignWebDataGridHeaders(alignment, names) { var i; var headers = document.getElementsByTagName("th"); for (i = 0; i < headers.length; i++) { var key = keyFromHeaderId(headers[i].id); var j; for (j = 1; j < arguments.length; j++) { if (key == arguments[j]) { headers[i].style.textAlign = alignment; break; } } }}
Currently I think there are two options - directly modify .igg_HeaderCaption th for grid header and set text-align to right, but this will affect all headers in the grid
The other option I see is by using templates, e.g.
<ig:TemplateDataField Key="ProductName"> <HeaderTemplate> <div style="text-align: right !important;"> Right </div> </HeaderTemplate> <ItemTemplate> <%# Eval("ProductName") %> </ItemTemplate> </ig:TemplateDataField>
CssClass for header is a good idea, maybe we will implement it future versions of the product.
