739
Can't figure out how to access headers
I have a WebDataGrid that I bind dynamically by setting its data source to a DataTable.  This works fine, but I can't seem to get at the headers programmatically to change the captions, etc.  I want to do this server side.  It seems like it would be easy.  Things I tried:
 1) Accessing the Columns collection during various control events.  However, Columns.Count is always 0.  I put this code in every single event handler:
      if (gridTickets.Columns.Count > 0)
             Debugger.Break();
and it never seems to get populated.
 2) I see a protected HeaderCaptions collection, but that doesn't seem write.
 All I want to do is set some basic properties of the headers as the grid loads.  It's a read-only grid with no paging, so I guess I could just use a repeater or program an ASP table ... any ideas?
  • 14049
    The columns should be set up either at design time or added at runtime
    before you call databind. AutoGenerateColumns should be set to false in
    that case.
