I just installed the ASP.NET trial product for VS 2008. I am getting an error message on the license key. How do I fix this?
If you are getting NO Liecense information found error - when dragging a NetAdvantage control onto a form in Visual Studio.
This error indicates that licensing information in the registry is not present or can not be read. If you are using a different account then the account that which installed the product, then i would suggest you refer to the following KB article.
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10023
Further I would suggest you do the following
Set “Full Control” on the following key in the registry for the “Everyone” group: HKEY_CLASSES_ROOT\Infragistics
Visual Studio must be restarted for any registry permission changes to take affect.
