We have been using the webgrid template feature extensively but are having difficulty in accessing the WebSlider control within the template using client side events. We've managed successfully to employ a WebDateChooser utility which allows us to access those features in BLOCKED SCRIPT
var combo1 = igdrp_getComboById('ctl00_ContentPlaceHolder1_UltraWebTab2__ctl3_UltraWebGrid4_ctl00_Grid4_StartDate');
We have tried using the following which exposes some features but we still can't seem to set nor get the value from the web slider using BLOCKED SCRIPT
var webSlider = document.getElementById('ctl00_ContentPlaceHolder1_UltraWebTab2__ctl4_UltraWebGrid5_ctl00_Grid5_WebSlider');
We've tried to access the CSOM functions but can't seem to connect the WebSlider object to them (Error: Object doesn't support this property or method)
Any suggestions would be most appreciated,
D Reinhart
Hi D Reinhart,
If javascript-based control is located in naming-container, then under dot-net using hardcoded value is not reliable. For now id-separator is "_", but a new version of dot-net may change that value and your codes will fail. For example, id-separator for UniqueID used to be ":", but now it is "$".
You may consider 2 of possible options:
1. Process Initialize ClientSideEvent and create a global member variable which will contain value of ClientID. Use that global variable when you need to get reference to control.
2. Use <%=Control.ClientID%>.var slider = $find('<%=WebSlider1.ClientID%>');var dateChooser = igdrp_getComboById('<%=StartDate.ClientID%>');window.alert('slider:' + slider + ' dc:' + dateChooser);
