How to get samples to run in asp.net 3.5? they won't compile. And, I also simply tried to drop a webtree control on a new project's default.aspx page, and I get the 'lc.exe' missing error. I'm using the trial version. How do I actually get something running?
Thanks.
Thanks. I found the sample files under the folder you specified.
On Windows XP, you should be able to find the samples in the following location once installed:
C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2008 Vol. 3 CLR 2.0\Samples\ASP.NET
This folder may be opened as a Web Site in Visual Studio 2005 or Visual Studio 2008.
I am using Windows XP professional. I have admin right. But the sample folder is still not available. The file I downloaded from Infragistics is NetAdvantageWebClient20083.zip. Anyway still does not work.
Are you running Vista? I am not sure what the deal could be, unless there is a permissions issue?
I did install the NetAdvantage_Samples_20083 after installed the CLR 3.5 version. I just installed the CLR 2.0 version, but the sample folder still cannot be found in the folder you mentioned. I checked the previous version of 2006 vol 3, and there is sample folder under that directory. Please advice. Thanks
