Hello! My problem is the following:
I'm having problem with the position with one WebDialogWindow when moved and it is minimized, with async postback enabled for this kind of action (move). The problem consist in that the WebDialogWindow appears in it's initial location, although the properties Left and Top have differents value, (and of course the InitialLocation property value is set to Manual). I can't put any code here. Any one had encounter this problem? Thanks!!
Next public hot-fix should be released around 12/20/2008.
We dont see any hot fix that has resolved this issue.
We have a problem with the WebDialogWindow, we placed the UltaGridView in the WebDialogWindow, every time the post back or partical post back happenes the UltraGrid will move out of the position, it will be moved to the top of the window, this all hapens because of the WebDialogWindow not able maintain its position.
Please help us.
Thank you for a report. Persistance of position when dialog in minimized state was fixed a couple of weeks ago. I think it will be available in hot fixes soon.
