60
Problem using WebDialogWindow with UltraWebTab
I have a page that contains an UltraWebTab with a collection of 8 tabs. on the 4th tab I have an UltraGrid each row on the grid has a button that opens the WebDialogWindow.
The problem is when the WebDialogWindow is made visible the you can only see it when you click on the 3rd tab. When you click on any of the other tabs the WebDialogWindow disappears.
 Does anyone know how I can make the WebDialogWindow visible on the tab page where the grid is located?
  • 455
    I have had similar problems with the web tab control. First make sure the controls located in the tab are not positioned via a table. Use a div and position it using css. Also use a ContentPane and set EnableRelativeLayout='true' There is already a support issue for this issue. I do not remember the number but it was entered on Sep 30. Lenny
  • 28464
    This one might be tough to reproduce based on the description. In cases like that I believe the best approach is to contact Developer Support directly, if possible, with a small subset of your project reproducing the problem, so that they can provide additional details. Additional info to the project, like enviroment, versions of the controls, etc, will also be very beneficial.
    Developer Support can be reached at:
    http://devcenter.infragistics.com/Protected/SubmitSupportIssue.aspx
