I have a webgrid where I want to calculate the totals of the columns in the footer. I created a formula in the footer section of the grid. This required the WebCalcManager control. Everything seems to work great until I edit the value in the grid. When I change the value of one of the cells in the grid, the total does not recalculate. What do I need to do to get the totals to recalculate?
Brian
If you don't have the grid's AJAX functionality (XML Load-On-Demand) activated, then you need to trigger a postback.
If I remember correctly, if the grid's AJAX functionality is active, this recalc happens as part of the process. I haven't tested this myself, though, so I'm not 100% certain.
What I am 100% certain about is that all WebCalcManager calculations happen on the server. WebCalcManager has no client-side presence.
