30
Error importing excel into Workbook
I'm trying to load an excel sheet into a workbook.   It works fine until I edit the sheet, but after I do edit it and try to import it I get
"'The left and top of the window bounds must be between -32768 and 32767.  Parameter name: value'"
Using version 14.1
System.ArgumentException
HResult=0x80070057
Message=The left and top of the window bounds must be between -32768 and 32767.
Source=Infragistics4.Documents.Excel.v14.1
StackTrace:
at Infragistics.Documents.Excel.WorkbookWindowOptions.set_BoundsInTwips(Rectangle value)
at Infragistics.Documents.Excel.Serialization.Excel2007.XLSX.PartManagers.ObjectModelWorkbookPartManagerBase.LoadWorkbookViewElement(XmlPartManagerBase partManager)
at Infragistics.Documents.OfficeOpenXml.Core.XmlReadManager.TryLoadNormalElement(QualifiedNameInfo elementName, String strictQualifiedName, Int32 currentChildIndex)
at Infragistics.Documents.OfficeOpenXml.Core.XmlReadManager.LoadChildElementsHelper(Int32 currentChildIndex, AlternateContentStatus alternateContentStatus)
at Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.LoadCore()
at Infragistics.Documents.Excel.Serialization.Excel2007.XLSX.PartManagers.ObjectModelWorkbookPartManagerBase.LoadCore()
at Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.Load()
at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.LoadPart(IPackagePart part)
at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.LoadPartRelationships(IPackagePart sourcePart, PartManagerBase sourcePartManagerPrototype, IEnumerable`1 relationships, Boolean hasSourcePartBeenLoaded, Boolean& wereRelationshipsSkipped)
at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.LoadCore()
at Infragistics.Documents.Excel.Serialization.Excel2007.XLSX.ObjectModelExcelDocumentManager.LoadCore()
at Infragistics.Documents.Excel.Serialization.WorkbookLoadManagerExcel2007.LoadCore()
at Infragistics.Documents.Excel.Serialization.WorkbookLoadManager.Load()
at Infragistics.Documents.Excel.Workbook.LoadXLSXFile(Workbook workbook, Stream stream, WorkbookLoadOptions loadOptions)
at Infragistics.Documents.Excel.Workbook.LoadHelper(Stream stream, String parameterName, WorkbookLoadOptions loadOptions, Boolean isStreamDecrypted, Nullable`1 format)
at Infragistics.Documents.Excel.Workbook.LoadHelper(String fileName, WorkbookLoadOptions loadOptions)
at Infragistics.Documents.Excel.Workbook.Load(String fileName, WorkbookLoadOptions loadOptions)
at Trident.Objects.Business.Stores.StockItemPricingBatch.ImportFromExcel(String filename, ICacheable pricingType) in D:\Code\Trident\Trident.Objects\Trident.Objects\Business\Stores\StockitemPricingBatch.vb:line 699
at Trident.UI.Business.Stores.frmStockItemPricingModule.ImportCommoditiesFromExcel() in D:\Code\Trident\Trident.UI\Trident.UI\Business\Stores\frmStockItemPricingModule.vb:line 191
at Trident.UI.Business.Stores.frmStockItemPricingModule.ImportCommoditiesToolStripMenuItem_Click(Object sender, EventArgs e) in D:\Code\Trident\Trident.UI\Trident.UI\Business\Stores\frmStockItemPricingModule.vb:line 181
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.RunDialog(Form form)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at System.Windows.Forms.Form.ShowDialog()
at Trident.Startup.Main() in D:\Code\Trident\Trident\Startup.vb:line 179
